shocker998md
- Jan 8, 2009
So my build direction has changed. Im just getting the engine put back together with new rings, gaskets, comp 980 springs and the factory turbo. I have the factory d5 converter and a PATS 3000 rpm stall that was spec'd out for a Turbonetics CPT61 and 60 lb injectors. Would there be any negatives to running the 3000 stall on a mostly stock setup? It will have 42 lb injectors, meth, turbotweak chip, 3 inch DP to 3 inch rjc cross flow, 255/60/15 tires and that's about it.
So stock d5 with 90k on it or the Pats? They are both on the shelf.
