I replaced my powermaster motor with a spare I had laying around. Reason for replacement, the other one was leaking fluid.
Before I had no issues other than it was leaking. With the replacement motor, when I turn the key on it cycles for about 15 seconds as it would normally do when one pumps the brakes to depressurized the system.
It does this after every time I go to turn the car back on. Brake idiot light comes on until it finishes cycling (15 secs or less).
Is this a symptom of a failing motor? Other than that the brakes seems to be working ok.
TIA!
Dannyo
TIA!
Dannyo
