120amp/140amp
First of all is your alternator in need of replacing,if so I would either stick with a factory 120amp A/C Delco or you can go to Advanced Auto and purchase one for a Impala SS 140amp its brand new(not rebuild)with a life time warranty. It will bolt right in,many GN owners go that route,the only thing I had to modify was I had to enlarge the hole on the one wire that is bolted to the back of the alternator,its a 8mm bolt not a 6mm bolt like the factory alternator.You will never need any more alternator than that.ikle
