buickGN3:16
- Jun 29, 2012
its deffinately time to do it but no good choices out there that i've seen yet that stand up to the volts needed! Any ideas..?
Take it to your local armature service and they should be able to do anything you want with better parts and cheaper than any auto parts stores.too pricey for me
I had a 120 amp in mine that I had rebuilt and I still wasn't satisfied with the voltage I was seeing installed the 200 amp power master rarely I see 12.5 volts it's typically 14 to 13.5. I can confirm Earls comments my scan tool read about .5 volts less than the volt meter when tested the back of the alternator.
