There are a lot of blown alcohol burners in this country and combustion chamber space being a major concern is not one I've ever seen come up. VE will always stop you first.I'm talking about burning them at their individual optimum a/f ratios.
For you there is no comparison. Methanol wins hands down because of the limitation you built the motor around. You couldn't flow what you would need through those heads to make the power you are making with gas. You intentionally put those limitations on your engine. As your ability to make that car faster grew you chose not to change the heads. You decided to work around the limitations they presented and challenged yourself to make the car haul ass DESPITE of the heads. I tip my hat to a job well done. I was thoroughly impressed with you and your car. You certainly know that if someone with your skill set and resources had a budget that was the sum of what you have invested in your car were to build a Turbo Regal from scratch with the goal of 1/8th or 1/4 mile performance in mind that they would not face the same hurdles that you do. (I wonder if thats the longest sentence ever typed on a messageboard?)
The VE of an engine can exceed 100%. You chose to limit your engines ability to ingest and exhale fuel and gasses by using the M&A heads. I understand that and think that it adds a very unique aspect to your car that I can appreciate. That doesn't mean that every car is limited by those restrictions though.
