Nasty Wendy
Perverted Lurker
- May 24, 2001
Plus, spark plugs, piston tops and combustion chambers are spotless. No carbon buildup. Less thermal loading of the engine components, lower exhaust temps, more products of combustion. No worries of the fuel quickly going stale. Milder flame speed.
And did I mention the famous wide tuning range of methanol? Reach your hands into the sky my fellow racers and give a shout out of thanks!
This ain't a which fuel is better for every reason except power thread, all he was asking is which fuel can make more power or rather go faster. I told him this shiggidity was going to get complicated....I TOLD HIM.
I'm used to that LOL. If you think my reasoning is flawed now wait until you see what I'm about to post next.Sorry to have to tell you, but your reasoning is flawed.
True, it takes about twice as much methanol to a given amount of air to come up with a stoich mixture compared to a stoich ratio with gasoline given a same amount of air, but take a closer look at the btu values for gasoline and methanol for the same quantity of each... Now take that btu value for methanol and times it by 2 because that's how much more fuel you're going to need to come up with for a stoich ratio with methanol. What do you come up with?
Given equal amounts of air and the proper amounts of gasoline and methanol to burn at stoich ratios, the methanol wins out, hands down.
Not enough room in the combustion chamber when burning methanol is more flawed reasoning. Sorry.
A stoich methanol/air charge is 6.45 lbs of air to 1 lb of methanol. Air will compress. Vaporized and for the most part dissociated methanol will compress. So why would there not be enough room?
I'm going to try not to type up a novel here.
A gallon of Methanol has ~ 62,800 BTUs.
A gallon of Gasoline has ~ 125,000 BTUs.
This shows why you have to burn twice as much methanol to make the same power as a given volume of gasoline. It takes 2 GALLONS of methanol to exceed 1GALLON of gasoline by 600 BTUs. Air/Fuel ratios aren't measured in volume however, they are measured in weight.
The specific gravity of Methanol is .791.
The specific gravity of Gasoline is .739.
Methanol is ~ 6% heavier than gasoline.
Comparing two equal weights of the fuels will show that methanol produces LESS THAN HALF of the BTUs of gasoline by weight. Take the weight of that gallon of methanol (62,800 BTUs) and take that same weight in gasoline and it will produce 132,500 BTUs. This shows that even though the stoich mixture for methanol calls for twice as much methanol (by weight) it won't produce as many BTUs as a stoich mixture of gasoline. In a situation where you are comparing using gasoline vs. methanol to a constant weight of air the gasoline wins hands down.
I had to go to the cliffnote version because this post was going to become a novel.
