I am slowly but surely installing Razor's alcohol kit with the help of a fellow board member and ran into a bit of a snafoo today. Mounted the pump on the passenger bumper support and this is where the problem has arisen. The line running from the alcohol tank to the pump is only about a foot and a half, much too short to reach the pump. Tried to mount it next to the battery behind the passenger headlight but even that was pretty micky mouse and was blocked by the plastic piece that holds the battery down. I did buy the kit used but from a very very reputable person on the board so my question is am i missing a line and if not where do you guys have your pump mounted?? PICS of the lines running from the overflow to the pump and of the pump mounted would be GREALY appreciated.
Thank you,
Brian
Thank you,
Brian
