Hi, I have a 87 GN and I just changed my tires from 225/55r16 all around to 245/50R16 in the front and 255/50R16 in the rear. First off at the tire shop I was told my upper control arms bushing and center link needs to be changed to get alignment done. So in leaving the shop and making a sharp turn I notice and felt the tire rubbing against the fender wall. I know to change the upper control arms bushing as well as center link. Since I’m in there should I change anything else? Is there a way to maybe higher the front to get that full turn so the tire want rub maybe taller shocks. I’ve never changed the shocks I’ve had the car for 3 years could they be bad. Any advice…thanks
