87GNcospg
Send your Donations
- Jun 23, 2003
how do i test to see if my shurflo pump is working?
i have razors alky kit and the pump seems to not be working. the turn on light comes on at 4psi, hitting the test button makes the light come on, but i havent refilled my alky tank in weeks. my alky has been at the same level for weeks. when i turn the knob on the controller box all the way to the right and hit the test button, my car would almost die from the alky being sprayed at an idle. now hitting the button at idle has no effect. no alky seems to be coming from the nozzle.
i took off the up pipe and left the nozzle connected to it. with the ignition on shouldnt meth spray from the nozzle if someone hits the test button?
i guess i will check to see if the filter or nozzle is clogged before i assume its the pump. . .
