WOW
I'm not trying to sound "opinionated" here but that is WAY HOT compared to that of other intercoolers I have seen including testing we any many others have done with stockers and modded IC's.
Assuming you had about 270 degrees entering the intercooler (which is high compared to your outside temp ) (giving you better efficiency calculations) and 50 degree outside temp....
temp in-temp out divided by temp in-ambient temp X100 will give you the efficiency of the intercooler...so here it is:
270-158=112 degrees
270-50=220 degrees
112/220=.50909090909 X100 =50.9 percent efficient for your V4 unit
we have seen stock intercooler efficiencies in the 60-65 percent range, but pressure drop with a stock intercooler is greater because of the tank and neck design, most of your gain with the V4 is probabally being gained in the pressure drop area....
We have also done testing with our intercoolers and have seen efficiencies in the range of 90% and greater...even in much warmer ambient temps...
Our reccomendation is if you are going to keep the V4 unit, strip the core and tanks with aircraft stripper, the powdercoating they put on those units is a VERY GOOD thermal insulator as compared to a bare or thinly coated (painted) core, I'd bet your efficiencies go up 5-10% just by stripping the core
