I made my own tester, this should give u an idea
Man - that is a great video.
Very clear and to the point.
And he has a good sense of humor - "He said duty"
I already made something similar out of PVC and quick couplers w/ a Filter / Regulator for checking the health of IC's that off the car and in the shop.
I used short lengths of PVC pipe with end caps - that are a little bit of a pain to put a fitting in to - since they are convex on the end. I didn't even think about just using plugs! Duh!
Also used some IC hoses that most of us have a box full of laying around.
Then keep it connected with the 25PSI and dunk the IC in a water tank - like checking a tire for leaks.
Great idea about the 3M adhesive though!
He uses a tire valve stem - which would imply connecting any air compressor to it, and give it a shot of air - just like like filling a tire..
( He probably assumed people would be smart enough to adjust the main regulator on the compressor side down from 100 to 25 PSI - or do it like filling a tire)
I made a separate Filter / Regulator with a shut off valve & quick couplers that I have permanently set at 25 PSI that I can use in-line whenever checking the boost side of things.
I think both ways are good.
This boost tester takes things one step further than my IC tester..
How cool.
Now - for a final upgrade - a smoke port!
