Issues!
Okay guy's, Here are the issues we are seeing. Been experiancing fluctuating fuel pressure for some time now. Not sure if it's the Gauge, Pump or the regulator. So I droped the tank and replaced the stock filter sock with a brand new one, Replaced the inline fuel filter, and now we took apart the regulator to check for debris. everything looked fine!
Now with the regulator back on the car...
With the BOLT OUT turn key to "On position" and the gauge shows 15lbs fuel pressure. (line off)..
Now, With the BOLT STILL OUT, The car will start and run and the gauge shows 40lbs fuel pressure at idle (line off)..
Is this normal for a car to still run whith the adjustment bolt completely out?
Just trying to figure this out whithout just throwing parts at it.
Thanks in advance!
Scot W.
