Clearing some stuff..
62 MM TB and plenum ported by Jay Jackson. The plenum in the drivers side rear has a hole for the ATS sensor tap'd. No IAC or tps included. Has everything else. $150.00
Henco upper for 70 MM TB $100 shipped
Billet top fuel pressure reg $60.00 shipped
Autometer Monster tach with shift lite part number 3904 $135.00 shipped
Autometer Electric pro-comp water temp 2 5/8 with mounting cup $35.00 shipped
Autometer Sport Comp 2 5/8 35 PSI boost guage with mounting cup. Guage reads 1-2 psi with no pressure on port.. but works 1-2 psi off. $25 shipped.
Set of 72's bendix injectors. 5 are bendix, 1 is a siemens. They work..need cleaning/testing/ etc. Will guarantee agianst being locked up/leaky. They were on car recnetly bought.. idled and ran fine. Step'd up to 83's $150.00.
Ashtray switch plate for GN. Has for 5 rocker switches. One is missing. So plate with 4 switches $15.00
Underdrive crank pulley with belt $35.00
Under drive crank pulley with mini pulley for alternator + belt $50.00
Hooker hearders for a GN $175.00
Be Cooling aluminum radiator with dual fans mounted. $300.00
Set of Weld wheels 15x3.5's, 15x10's. Fronts are new tires.. rears have been drilled for screws and have a nice set of 26x10 MT slicks. These can deliver to the Nats. $600.00
Stock unmolested intake of my 18k mile TTA. No stripped/repaired holes/no rot, no issues.. $175.00
More stuff soon...
More stuff soon...
