Well guys, I think I may have narrowed down the issue with my car, but I wanted to run my thoughts/feelings past you guys and get your opinions. I'm sick of throwing parts at this thing, and my "toy" fund is getting lower. I really just want to enjoy my car, so, be honest, and tell me what yall think.
A little background first:
My car has a sumped stock fuel tank, and is using a Bosch 0 580 254 984 pump. I talked to the guy who built my car for the previous owner, and he said he was a cheap ass. Long story short, when the sump was welded on, and the tank was blasted for re-finishing, it was done with the filler cap off, and I ended up with a bunch of crap inside my tank(prior to me owning it). I guess dude got sick of spending money on aeromotive inline filters, and stuck a plastic carb style filter in the line. Well, the pump made quick work of the filter, and is drawing fuel AROUND the element, instead of through it. My thinking is that some of the crap in the tank made it through, and the pump is shot.
As the car hits boost, I can see fuel pressure plummet. I have it set to 43lbs line off, and it comes down to the 40-41 range line on. I have re-done all the vac lines, and replaced the rubber vacuum boots on my regulator. The car looses pressure so fast that the most boost I have seen out of it is around 2lbs.
Here are my questions:
Do you think the pump is shot for sure? I know it is REALLY loud, and sometimes changes pitch at idle.
Is there a chance I have a bum regulator too? I was always told a bad reg would spit fuel from the vac fitting with the line off. Mine seems to be fine. Is there any other tests I can do?
Is there a different pump you guys recommend? I was told that a 255 would flow enough on my car. Is there any truth to this? Looking at flow charts, the bosch flows about the same in the mid range, but keeps pulling in the upper scales where the Walboro falls off.
I have a Aeromotive 100 micron inline filter for the feed to the pump sitting here on my desk, but I was told to run a 40 micron on the return. Do I need to do this? Any recommendations for that if it is needed?
I was thinking about having my tank cut open, cleaned, and sealed. Is this the way to go, or should I just spring for a Fuel cell? Both are about the same price. Is there any reason to do a large cell on a street vehicle? If so, foam, or no foam?
Should I have my injectors tested?
I think thats it for now. Sorry about the long post. I dont have much money to keep futzing with this right now, and I want to have my car for at least part of the summer. Thanks in advance!
-Todd
-Todd
