93 mustang trunk
Thread Tools Search this Thread Display Modes
09-13-2009, 08:58 PM #1
mikeextrafast
Registered User
Trader Feedback: (0)
Reef blue coupe roller
92 reef blue coupe roller clean title
orig. v8 5 speed car
6 point cm cage tig welded
all stock interior
new carpet
new door panels
tinted windows
new door handles
new seal plates
8.8 rear end cut 2" each side
3:55 gears w/spool
big 9" end with strange disc brakes 5/8 studs 5 lug
anti roll bar
coil overs
factory wheel tubs cut and moved in
35 spline axles
15X10 welds w new 325/50/15 drag radials 15x31/2 in front
all UPR uppers and lowers
frame connectors
optima red top battery in trunk (new)
15 gallon alum. fuel cell mounted in trunk (new)
flaming river disconnect
stock carpet panels in trunk
700$ magna fuel fuel pump w filter (new)
flex lite 10 an hose run to front of car
UPR tublar k member
flaming river rack w/ steering shaft
caster/camber plates
wire tuck
coil overs
adj shocks
paint is in good shape ,car has a 2" fiberglass cowl hood ,new tinted head lights
super clean inside and out
$5,800
send email for pics
Off topic
mikeextrafast
Registered User
all stock interior
new carpet
new door panels
tinted windows
new door handles
new seal plates
3:55 gears w/spool
anti roll bar
coil overs
35 spline axles
frame connectors
UPR tublar k member
wire tuck
coil overs
adj shocks
$5,800
send email for pics
How do you or did you like that UPR stuff? Good fit K member or would you have gone another route next time? Thanks Scott
