86/87 T Type/GN Used Parts
tbirdv6
200r4 tranny BRF,Out of a 87 GN
Had a recent stock rebuilt, but was noisy-pulled drive shaft & tail end ball bearings came out
Shifted nicely before & during noise
Maybe all it needs is new tail shaft bearings?
Most definately good for a core if nothing else-make offer?
Factory Oil cooler adapter and lines-2 complete sets available-$50 ea
used-but in nice condition stock 200r4 tranny pans-$30 ea
Nice tranny inspection cover-$35
Red's Volt Booster-$35
NEW
STOCK FAN $25
STOCK T Type HEADER PANEL-Nice Condition & Orginal- $150
86 T-TYPE GRILL $25
STOCK PASS SIDE HEADER $75
RADIO FROM A 442 FITS/WORKS $25
GN CENTER CAP $10
2 REAR GN SEAT BELTS (PULL OUTS) $20 ea
FRONT FIBERGLASS BUMPER FILLER-$30
AIR DAMS $20
HEADLIGHT BEZELS- 2 CHROME-$15 ea, 1 BLACK- $35
FRONT TURN SIGNALS UPPER CHROME $20 ea
VDO-Competition Series Gauges 2 1/16
EGT w/Probe= $60
EGT w/o probe= $40
A Pillar Guage Holder (2 guages) matches GN Pillar-no cracks or scratches,but has alittle warpage(florida sun) but still fits great-just not of show quality (only if your very particular)
$10 w/any above gauge purchase
1 Piece Anodize UnderDrive Crankshaft Pulley -$50
Brand new 4 x 10 to 6 x 9 speaker adapters-$20
EGR Block Off Plate -power six logo-$15
S & B Filter (7") Chrome, has difuser & cone opening @ end as to being able to run a flex hose to it to pick-up more air (cold?)-fits our 3" mass air-$25
Coil Pack Bracket-$25
Stock Intercooler Brackets (2)- $50
Alternator(120 amp)-$35
Starter w/bolts-$25
Complete Rocker Arm Assembly(2) (Shafts/Rocker Arms)-$30
K & N 14" Filter-$35
Rear Bumperettes (2)w/rubber pads-good condition-$50
Chrome Powermaster Resevoir Lid (lightly pitted, great 5 footer) $15
GN Console Lid w/Hinge (no rips ,tears, or cracks)$35
OEM Timing Gears(2) & Chain-almost new(Nylon Gear-no signs of wear,no chipped teeth)-$35
EGR Vacuum Control-$35
Crank Pulley-$25
Metal Lines that start @ vacuum block & runs over to Drive Side-$35
Door Sill Plates (pair) $40
Thrasher 50 lb inj. computer chip-$25
turbo shield bracket(bolts to the head and to the turbo for the shield)-$40
Chrome/aluminum rectangle headlight retainers(4) -$25
AlkyControl Pump aka Razor- never used since refurbished(upgraded & bench tested)$100
Up Pipe(intercooler to throttle body) drilled for alky nozzle-$25
Shipping not included
Accept Paypal(add 3%)Acct= turbobuick4@yahoo.com
FRED
NEW
STOCK FAN $25
86 T-TYPE GRILL $25
GN CENTER CAP $10
AIR DAMS $20
EGT w/Probe= $60
EGT w/o probe= $40
Starter w/bolts-$25
Crank Pulley-$25
FRED
pm send on up pipe, egt, egr cover.
brf trans
I was wondering if you would part out trans if stock unmodded valve body br3 and governor, servo, speedo gear and governor and lock up solenoid wiring thanks....
It would be cheaper if you purchased the whole tranny
I would charge extra for tear-down time
FRED
Ill take the black bezel if not distorted or cracked, the egr block off and the alternator if its still good to 06492.
would you take 100.00 for header panel also does cooling fan work thanks
cooling fan works
I'm in the middle of finding shipping cost for shipping header for someone else-only way i would take less if someone were to pick-up & save me the hassle to ship
FRED
is the cooling fan ready to plug in also let me know what shipping is see if we can work something out thanks
What part of the country are you in Fred ?
That's always nice to know in a F/S ad... :cool:
