Hey,
I'm back! I pulled the 454/TH400 out of the Turbo Regal & dropped it into a 1964 Nova (Stevesnovasite.com - 1st gen non-tech - Project Idea by GS Jimmy) whole bunch of pics & what not at that site.
Anyway, here is my dumb question. OK, not so dumb, as I know it has been done before. I'm going to be restarting the Regal project this summer and will be using an intercooled 5.3 (LM7) LS based v8 & GN stock turbo (something like 400+ HP with good gas milage). I already have the TH700 R4 sitting in the garage (from an '86 G20 Van w/5.7 v8) that was rebuilt once already. I'll have it gone through just to be sure that it's up to snuff.
What all is involved with putting a 700 into a G-body? I already have a crossmember made for the TH400 that was in the car before (double hump to run duals). I'm guessing that I'll need a 400 transmount (dual bolt pattern) and will need to drill new holes in the frame to mount everything down.
So far this is what the project will have:
5.3 LM7 Vortec (2001-2005 GM Van or truck)
Painless wiring
GM computer - reflashed
TH700 R4 trans
4" driveshaft
8.5" rear end w/3.42 gears
Intercooler
GN Turbo - stock w/blowoff valve set to 6lbs
Will the trans hold up to this combo?
Thanks,
Jim
Painless wiring
TH700 R4 trans
4" driveshaft
Intercooler
Thanks,
Jim
