Which turbo would you guys recommend me to upgrade from my CPTE44? My goal with the car is low 11's high 10's around 23-26psi. But Id like as much as I can throw at the combo. My setup right now is;
3.8L, stock crank and rods, TRW Forged pistons (8.1:1 compression)
Stock rebuilt 8445 heads w/ 100lb springs
Erson 208/208 flat tappet cam
Stock lower intake w/ 70mm TB and Upper plenum & RJC PP
#55 injectors & TT Chip
Alkycontrol Methanol kit
3" DP w/ HKS External WG
3" MAF Pipe w/ factory GN MAF Sensor
Stock Intercooler w/ Duttweiller neck
TH400 Trans w/ 3200 Stall converter
3.23 Limited slip rear axle
27x10.50x15 Slicks
If I missed any info let me know. I am wanting suggestions, I wanna get some runs in this year!!
27x10.50x15 Slicks
