machinegun
- May 25, 2001
What I have been thinking of is a street LENCO setup with a convertor rather than a clutch. Manual shifting up and down but a TC to torque against. Any possibilities of this?
Originally posted by turbofish38
Okay, I've been following this thread and riddle me this. Now Ive never driven a turbo car with a stick but if there is a issue with turbo lag between shifts than wouldn't that be the number one complaint with the rice boys and snobby Porsche turbo owners? How are the turbo Porches and Subaru WRXs getting away with it? And back in the 80s there were a few guys roadracing Stage 2 turbos in all types of configurations( just look in the front of the Buick Power Source Manual) not to mention all the Indy cars running Buicks. Sure you cant build boost on the line with a stick but I asked a ProMod driver running a supercharged engine and he said their technique was to side step the clutch to build boost on the line. It seems to me that it could be done, its just that the engine would need to be tuned and setup for a manual instead of an automatic. Personally I have ran my GN in a few track events and when set up properly the automatic out performs the stick cars. Using the engines torque to power through a corner is a hell of a lot more fun than rowing through the gears. Also on the strength issue a Viper puts out what?, about 550 lb/ft of torque through a T-56 so there are a few trannys capable of handling the power. Eric Fisher
Originally posted by GNVAIR
The older Porsche 911 turbo's were much smaller displacement and got away with a small turbo. The newer ones are approx 3.6 liters and use twins for faster spool up. The WRX is only a 4 cylinder of I belive 2.2 liters and as such can use a small turbo.
The only way to do it right with a Buick is if you run twins.
I really wish someone would waste their money and just do it for cryin out loud. It seems like no one wants to listen to those of us that tried it.
If thats the case when an auto shifts some load is taken off the motor. I do know that on the T56 the gears are close enough that you don't lose much rpm when you shift. And if you do lose some load wouldn't a BOV help.Originally posted by BLACK6PACK
Nitrousmike175,
Even with speed shifting and not letting off the gas the load will be taken off the engine when you push in the clutch. So you will still lose boost. The amount may be minimal if you are good at speedshifting though.
Originally posted by monte_383
Some of us 4 cyl guys have swapped to larger turbos (I'm running a Garrett T3/T04E) and have moved the powerband up ~1000 or so RPM, and its not any less fun to drive daily. I can't see where the powerband falls would make such a big difference on the choice of transmissions tho. Maybe depends on application (drag/road race), like was previously mentioned? -Chuck
Originally posted by Mr. T
I am going to keep my opinions and my intentions about Turbo Regals and manual transmissions to myself... mostly because Lee carries a bit too much NJ 'tude when it comes to this topic, more than I can handle in a public place anyway. We have been through it before. LOL.
I will say this:
Paul (Sleeper) knows about my intentions for creating a false load on the turbo. I'll leave it at that... the rest of you will learn the solution when I am done school in a year or so.
Out!
It will be funny watching you spent $5K to go slower. But again, you are an expert so I am sure you are already trying to reinvent the wheel
