The T-5 Behind my buick did just fine, the motor ran smoother than ever with the extra inertia helping it and I dont have a BOV at all. I run a 10.5" clutch, a diaphram pressure plate and the trans is a camaro W/C T-5, it holds as long as I dont drop it from 3 or 4K + RPM. However I have never dropped the clutch from higher than that as a drop on the clutch is more harmful to my drive shaft and rear than anything, and traction is more of a worry than the rest of the drivetrain, I just try to use a rolling start and letting the turbo do its thing.
It has been almost 2 years on the street - everyday driving to and from work. I could say it would go further, but a head gasket has led me to pull the engine for a rebuild and if the motors out, might as well change the clutch and check the trans. SO in light of that, I will report the wear to the thrust bearing on the crank as well as on the flywheel, clutch and trans.
I say go for it if you want it, its actually alot of fun to drive a turbo V6 with a stick..... Boost builds fast - and damn it sounds really cool when shifting.
A.j.
