Adam- 84 Buick
- Sep 29, 2015
Hello, I have an 84 Buick Regal limited. As of right now the car has a 350engine / turbo 350 transmission. 87 gn 8.5 rear end (4:10 posi). I have a 5.3 / 4l60e. The 5.3 has a gm hot cam in it and the transmission has a shift kit. Other than that, the engine and tranny is stock. I understand all the wiring and computers. What I was wondering about is engine mounts, fuel system, and anything else. What kind of psi fuel pump can I use ... I would like to use the stock tank. Originally this car came with a 6 cylinder. Not knowing what kind of psi the stock pump runs at .. Would it be enough for this 5.3.. Right now I have a mechanical fuel pump for the 350... Fuel lines that connect to on top of the sending unit (stock sending unit gutted of a fuel pump). Also , I need to get a different output shaft for the transmission.(for two wheel drive) and will I need a custom drive shaft made? Will my 350 engine mounts work for the 5.3?
