- May 28, 2001
86T Type, column shift car, 4L80E/LS turbo combo. I am making up the shift linkage w/ the LOKAR shifter and shift position system, and have run into a 'snag".
The OEM v-6 linkage lever on the column is too close to the firewall to use the LOKAR shifter rod.
[Using the cable style is not an option.]
So far, I've managed to find the 2 rods, a spring, and the frame mount brkt. There's also a rubber grommet that is hard and distorted, and a plastic sleeve on 1 end of the rod.
My shop manual is only for the engine....No body stuff in it, so I'm not sure what I may be missing.
IE: Engine end support brkt, what goes in the frame brkt socket, etc.
Has anyone hooked up/modified the stock linkage to work? NE1 have a drawing/pic I can use?
TIA,
TIA,
