Hello everyone, I wanted to bring this topic up for discussion. Recently my stock MAF went on me, and now I am looking to find a suitable replacement. Since I was doing it all over, I figured I would just go with a 4" set-up and never have to worry about it again. I've been reading and researching quite a bit over the past few days, and the general concensus I have heard about the 4" card MAFs is that they cause idle problems, and problems at cruise with cutting out. I researched this on LS1Tech and found that people using the LS7 sensor were also having these problems. I stumbled across this thread:
http://www.hptuners.com/forum/showthread.php?26546-100mm-Maf-kickin-my-Butt!!!
and here is the link to the honeycombs:
http://www.saxonpc.com/100mm-cells-for-100.html
Now, I am curious, do you think the honeycomb or airflow straightener will work? Could that be the solution to the MAF problems some people have been having with the LS7 MAF? Or is it something to do with the MAF Translator? The reason I was looking at these sensors is because A. They are cheap B. They have an IAT sensor in them and C. They are just a weld in flange.
Please discuss,
Thank you,
Zack
Please discuss,
Thank you,
Zack
