It's incredible what it takes to get a "simple" motor together. I added up parts receipts the other day and discovered more than $6000 have been vanquished from my account. Add in $3900 for machine work and it's no wonder I'm considering getting another job.
Here's what's in there:
Buick Motorsports steel crank
Carrillo 6.5" steel H-beam rods
All four steel caps
CP custom 9:1 pistons
ATR roller I think it's 524 lift
$80 junkyard heads ported intakes & un-shrouded
the biggest valves that fit in those tiny heads
Scorpion roller rockers
SB chevy rocker studs
ARP bolts
Fel-Pro gaskets
RJC plenum
RJC power plate
RJC pulleys (NICE!)
Gasket matched lower intake
HR P&S urethane motor mounts (no more worries)
I intend to run 25# of boost if the injectors will allow it.
The rest is in my sig
What do y'all think it'll run?
I may save it's innaugural run 'till Vegas since the timing may be perfect. Oh, my. I'd better get a room.
All four steel caps
ARP bolts
Fel-Pro gaskets
RJC plenum
RJC power plate
RJC pulleys (NICE!)
