When installing a 3" downpipe to a stock turbo, do you just use the stock replacement "doughnut" to mate the downpipe to the turbo. The new doughnut I have is like a graphite material. Also, the original bolts with the shank and springs will not fit the 3" pipe. The pipe is too large on the inside bend (bolt is too long) to get the bolt in the hole of the flange and on the outside bend the spring will not seat onto the flange (the spring interferes with the pipe itself). I got the downpipe from Kirbans. Do you just use regular bolts (metric of course) and snug them up. How tight should I go with these bolts? I don't want to ruin the doughnut but I also dont want it to leak and have to replace it later. Any tips or tricks? Thanks Mark
