if its not an alkycontrol.com alky kit i cant see what you would gain with a 3bar map sensor as his is the only one using one that i know of . the advantage of the 3bar comes with the use of the alkycontrol progressive controller as the 3bar allows for alky flow control up to 30psi of boost
digital to analog can and has been done before but its no small task and not for the novice , easiest is to get an anolog cluster , analog carrier , an analog dash harness and speedo cable assembly and drive gear for tranny and go to it .
harder would be to try to do without the analog dash harness and get the connectors for the analog dash cluster and tach and rewire the digital harness , you would need the service manual and some skills to pull this off
