T TT/Ameasap The White Blur Joined Jan 31, 2002 Apr 28, 2016 #1 Can we go to a 3/8" pushrod with TA aluminums?
B BARRACUDA1968 Well-Known Member Joined May 4, 2011 Apr 28, 2016 #2 I don't think so. I may have asked the owner of TA Performance if I remember right when I ordered my rockers. 5/16 will be plenty anyway.
C Chris Hogeland TWISTED 6 RACING Joined May 28, 2006 Apr 28, 2016 #3 You can but you have to clearance the head to do so. I run 3/8 on most builds I do. Sent from my iPhone using Tapatalk
F forcefed3.8's Buckeye Bullet Joined May 26, 2002 Apr 28, 2016 #4 If you are running an aggressive roller cam, you need a 3/8 pushrod to not flex with the springs these cams require. You will also have to trim the valve cover gasket.
R Robert Wilson Member Joined May 26, 2001 Apr 30, 2016 #5 3/8" to 5/16" tapered pushrods could be an option for you. I use them currently.
