foregn2 said:
Ok i'm kinda new to this but please be patient as I'm willing to learn. What is the TV and where is it located
TV is the trottle valve wire located on the throttle body, very top black sheathed wire with a silver wire that easily snaps to the throttle linkage, and connects to the transmission.
Alot of times, this is set too tight (pulled too far back to the firewall).
If the car seems to shift fine at normal driving, then dont touch it...
If one day the car seems to shift really soft, then if you look at the cable, its adjustable. Lots of times the cable will pop loose internally, and cause the car to shift like a slug. Put your thumb in the middle of the cable block, there is a part that looks like a D, your thumb will fit perfectly. VERY HARD to push in. Push the D in, pull the black cable back toward the firewall,remove your thumb from TV block, ratchet the throttle forward all the way Wide Open Throttle (ENGINE NOT RUNNING) You should hear the cable click forward towards the radiator, then push the D in one more time, and take the cable back towards the firewall ONE more click 1/8th inch
Anyway, if your still using the stock tach, then its probably reading too high.
My guess, if the car just feels like its not pulling, it could be just running out of steam on the top end.
What kind of modifications are done to it?
BW
