cjacobs said:had them on my 86 t-type , no rubs at all with 4" bs on center lines, still use them @ the track.
XxDarkSidexX said:what about an 86 GN wheel?
will the 275/60/15 fit with out a spacer? I got springs and airbags but stock wheels and would love to get a set of 275'50 or 275'60s if they dont rub. But I havn't put the car up and checked the measurments myself yet, still waiting for my fast system and other parts to start the project. Thanks.
machinegun said:personally I recommend the Mickey Thompson Drag radials. Use 275 60 15 and they should not rub.
flattype said:Wont a 28 inch tire be too tall for a fairly mild (te44 208/201 cam stock heads) car?
UNGN said:The 50's are more likely to rub on a GN wheel than a T-type wheel.
A good choice for the GN wheel is the 255/60 M/T drag radial or for longer street life, the Nitto 275/60, which is narrower and slightly shorter than the BFG 275/60... and should last twice as long in street use, due to its thicker tread.
XxDarkSidexX said:which nitto do you recommend?
