Hi!
Got a 7 van pump that has seen som converter parts flying by so I bought a another used body that had minimal wear and though to move the high performance parts and a new 10 van pump but saw a difference in the housings that I'd like to know more about.
The pump that came with the tranny has 088 on the pump housing while the pump I bought as an replacement is made 1984.
The above is the image from the used one I bought that has good pump surfaces.
The above pump was the pump that came with the tranny and is a high performance version.
The holes goes into the pressure side on the van pump so my question is, is this a normal mod to do to get more fluid out or is this because the pump has the 088 stamping on it?
Is this mod necessary?
The pump that came with the tranny has a hole that is 11.5mm in diameter and the used pump housing has a hole that has around 7.5mm
Any hints and suggestions is highly appreciated.
Best regards
Pelle
Best regards
Pelle
