11secmonster
- Jul 11, 2005
2007 DODGE CHARGER SRT-8,BLACK,19900 MILES,FLORIDA,1 OWNER,NO NAV.
425 HP BEAUTY!!
28,000......
MIKEYGOLD@YAHOO.COM
425 HP BEAUTY!!
28,000......
MIKEYGOLD@YAHOO.COM
Traded...sold
1999 T/A AND CASH...11 SECOND CAR WITH AC
WILL SELL FOR 14K
1999 Pontiac T/A Blue Green Metallic
42k Original Miles
Stock Bottom End
AFR 205 Heads with 921 springs
Traks Cam
Fast 90 Intake(ported by Jeremy Formato)
NW 90 Throttle Body
Ported Oil pump
Hardened Push Rods
Speed Inc Fuel Rails
42lb Injectors
Moser 12 Bolt w/spool 3.73 gears narrowed 3" on each side
Boyd Timeless 2 17x9.5/17x11 Custom offset.
Vredestein Tires
Hawks Brake Pads
SJM ABS delete
BMR K-member/a-arms(upper and lower)
Transmission Physicians built 4l60e
4000 n20 Vigilante stall
MTI Lid
Pacesetter Long tubes/tsp ORP with hokker cat-back
Aluminum n20 Driveshaft
BMR Adjustable LCA
Arizen Seats
UMI Torque Arm w/DS loop
RaceTronics plug and play fuel system
Grant steering wheel
Electric Water pump
Underdrive pulleys
Wideband in car
Qa1 Front struts
Comp Eng rear shocks with bmr springs
Aftermarket polished aluminum valve covers
Suncoast Raptor Hood
California Indoor Car cover
UMI Drag Sway Bar
New Aftermarket black carpet
Rear seat delete
Edead Sound Deadener on the floor and doors
Both windows have had door crack fix to prevent normal t/a panel,problem
Both Window motors have been replaced
Passenger had relay kit to roll down faster
200a Alternator(car idles with radio blasting without dimming)
Big 3 wire upgrade
2 Re Audio 10's in stealth boxes
Polk audio seperates in doors and sails
Rockford Power 1000 5 channel amp
Alpine head unit.
Car has a black center console
