i agree with this. Life of direct is limited if everything isn't perfect. Leakage and inadequate pressures even if hole sizing and calibration is correct can cause very rapid failure. Trying to find a good trans to work with is a challenge. The internal components are worn typically and cause problems. Trying to find a usable drum or even a drum that can be "cleaned up" is difficult. Building a high hp th400 isn't cheap either. For a lot of people it is worth it to run a 400 at that level. If converter design is correct the 400 can be cruised without overdrive and about 30% more rpm in 3rd. This is not a lot imo and I hear so many mention mileage. Your mileage will still suck with overdrive and everything perfect at low 10 sec level. Even if 20% of mileage was lost it's still not a big deal. If you are familiar with a 200-4r and what it needs it's usually worth pushing it. It will take repeated 140mph passes if everything is right.
