2 nozzle alky or single nozzle
stevek
When do you go to a 2 nozzle alky spray from a single nozzle, does the duel nozzle cool the air more on hotter days, if running high boost levels is a 2 nozzle better any opinions or knowledge will be helpful, and how hard to add another nozzle on if needed thanks.
Who's system? Alkycontrol can add a sec nozzle w. a kt.
As far as when to use 2........Unless it's a 9 sec ride, I think not.
Once the air fuel is where it needs to be, and the Gain is on 8... and you see knock.. then its time for the extra nozzle as you need more volume.
