darkred87T
- Oct 27, 2003
Hi, I'm selling my 1987 Turbo Regal. The car has 125K on it but as you can see from the pics, alot of work has been done to it. Iv'e owned it since 2003 and had it painted in January of 2005. The interior is out of an 86 V8 limited with 25K miles and is immaculate. Also I swapped the doors from the 86 before it went to the body shop and they are both solid as well. The car is solid all around and rides tight and smooth.
A little bit of history:
I bought it from my uncle in 2003. He owns a salvge yard out in PA and bought the car at an auction. It was abandoned at a repair shop somewhere in PA so for that reason only it has a Salvage title. It was bone stock and a little run down when I got it but there was never any sign of it ever being in any major accidents. I also have all of the receipts form every repair major and minor that's been done to it since new (apparently I'm only the second owner). I have all the stock parts for it including the original buckets, console and column. However I only have two of the stock rims as two of the others were cracked around the hubs so I had to chuck them.
Here are the mods:
Recently rebuit .030 over stock engine.
Champion P&P heads and matched P&P intake.
EGR bypass plate
206/206 roller Comp cam and roller lifters.
Precision GT3255 turbo
CAS V4 stretched stock location intercooler
Razors PAC alky
CK Performance 200R4 with 3000 stall converter
ATR Jet Hot coated headers
2/12" Hooker cat. back
Walbro 340 "hotwired" fuel pump
RJC power plate
Dual airbags
Like new 275/60 ET Streets (no track time on them yet)
Caspers boost and knock guages
Autometer Oil pressure and water Temp
Brand new battery
ENGINE MANAGEMENT AND ELECTRONIC GOODIES:
Translater Pro Speed Density conversion with Extender Pro chip
Power Logger
LC-1 WB02
EGT sensor
All other sensors are new.
All new vac lines and vac tree.
Iv'e gone as fast as 11.8@112Mph with it in the 1/4.. The last time I had it out I was trapping high 113mph (in third) with the 275 50's but I think the car has a lot more in it.
Asking $7,900
Here are the mods:
EGR bypass plate
Razors PAC alky
RJC power plate
Dual airbags
Brand new battery
Power Logger
LC-1 WB02
EGT sensor
Asking $7,900
