Be aware the T&D shaft system may or may not be a "Bolt-on". It comes out of the box ready for a cam with .650" lift, so if you cam is smaller and your valves are lower or higher than what T&D used for their set-up, the shaft will have to be lowered or raised. No big deal, unless as you raise the shaft the push rods get closer and closer to the push rod holes in the head, and if they hit the head, as in my case, you will need to remove the heads and grind away until there is enough clearence. Your push rods have to be dead-on perfect for these rollers and you must purchase them from Champion as the end that goes in the roller is specially designed. If you decide to stick with the Scorpions, I found some helpful info in the TA catalog about the proper way to adjust stud mounted rollers (push rod length being very key to proper geometry).
Mike
