1987 Grand National 37,824 original documented miles, build sheets, documents for all work done, a/c,tilt,cruise,a/m f/m cass.
Mod's: 235 Ci TRW's with billet caps and balanced,ported/polished heads with 1.77i and 1.55e manley stainless valves, harlend sharp rockers, quad air xp fuel pump, adj. fuel pressure reg, accel fuel gauge, hot wire kit, accel volt booster, Te-45a q trim turbo, percecion intercooler, T-400 trans will cooler, 3500 percecion stall convertor, 3" stainless THDP, Jet hot exhaust 2 1/2" ATR Manderal bent, 62mm Jay Jackson throttle body, 55 lbs inj, modded ecm, turbo tweak race and street chips, trans-plus,auto meter guages,duel fans, comp. cam 212-206, ATR rear sway bar, comp. eng. adj. upper/lower control arms,new mini starter,MT drag radials,drive shaft loop,direct scan, and I am sure there is more.... Drove to the track with the kids in back with the A/C cold and went 11:80 on a conservative tune,low boost and timing, babied it down the track. I know it has low 11's possible high 10's.
$17,500.00 Car is perfect inside and out. professionally done.
serious buyer only please. 1-734-693-1692 tgamino@yahoo.com
