I've written some extensive postings on all my trials running a turbo at high boost pressures so if you get bored do a search on 5831 and you HAVE to treat the car with tender care when running as much as I am. The slightest lean issue can blow a motor. Do NOT wire the WG Closed with this turbo It will produce more boost than studded heads can handle.
The RJC controller is a simple Grainger Valve which is what I had but I made it myself before Jason was making them. It was NOT steady at higher boost levels at all so I tossed it in favor of the one mentioned below and I recommend it.
Another note. The wg puck kept getting blown open due to the pressure in the exhaust housing when running more than 26psi. I had to get an VERY strong spring to help the actuator hold the puck closed. The one I chose the first time would hold things steady up to 30psi but fluctuated above that. So I got an even HEAVIER one. Now it's rock steady at 35psi.
Another-Another note: Above 26psi my up-pipe would blow off the throttle body and when it did it destroyed my perfect hood liner. I fought this issue using different hoses, a multitude of clamps and NOTHING held it on. So I made a boost brace and that solved the issue. Do a search for "boost brace" to see pics. If you value your hood liner take it off until you KNOW the up-pipe will NOT come off with higher boost. My new one cost $700. OUCH!
Here's one of my postings:
Update:
I got my boost control all figured out and I'm using this controller instead of my Grainger Valve and now the boost is setting at a steady 29psi with this turbo:
If you're wanting better boost control then I definitely recommend this unit although the instructions suck![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Turbo Review:
When running this much boost the flapper valve was opening on it's own due to the pressure in the exhaust housing so I was told to put an extra spring on the WG rod. That worked perfectly. I did NOT open the wg hole any more than what it came with but I did blend the inside radius with a die grinder.
As far as the Precision 5831 turbo goes, I LOVE IT.
Up to 22psi there is no difference in power over the stock turbo on my combo (stock long block) and there is a tad more turbo lag up to about 4psi but not much with a 2800 stall. Once it hits 4psi then the boost is instant. With a stock D5 it will feel the same so DO NOT let this little bit of lag deter you from getting this turbo.
When running 23-24psi you can really feel the difference starting to come through over the stock turbo.
At 25-26 psi the stock turbo can't keep up and the 5831 starts making real good power that can really put a smile on your face.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
BUT, the fun doesn't
begin until you hit 27psi. On my combo there is a huge difference between 26psi and 27psi that can really be felt and this leaves you wanting just a bit more. You can stop at this boost level and be perfectly happy.....if you want
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
At 28-29psi this turbo simply makes power! It feels like this is a very comfortable boost setting for this little hairdryer and this is where I am leaving it b/c the power this combo is making is just fantastic. It will light up the tires at 50mph at will and I need to feather the throttle to keep the tire spin controllable.
Yes, I've had it to 30psi and it feels very comfortable at this pressure on my combo but once you get to 28psi or more the car is making so much Stupid Power that it's just a waste of alchy on the street.
Oh yea, this is all on 91 octane and alchy![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks for all your help!
Regards
Kevin Slaby
