How is the little z clip removed? The clip that connects the gear pawl to the piston / plunger that goes into the valve body . Mine was installed backwards, therefore I can't get all the gears.
If you can't get it over far enough by doing as Chris suggested, you'll have to drop the valve body. Not too hard, just keep track of the check balls on top of the separator plate.
