After changing a timing chain, how long do you need to prime it for?
What happened with mine is that I used a priming tool but only for about 30 seconds as once I saw about 40psi on my gauge I figured that was all it needed.
After putting the cam sensor back in and firing it up, the oil pressure went up to about 80psi and then almost immediately fell back down to zero so I immediately shut the car off.
Is it possible that I just didn't prime it long enough and there's an air pocket somewhere?
I don't have the oil cooler installed so using one of those lines won't help me out.
