Are you after the whole setup or just the Modine sandwich bit? (black bit) If you are just after the middle bit (Modine black sandwich cooler) I got a spare I can part with. Drop me a line jlarsson@london.com and I can shoot you some photos.
The oil change shop I used bent mine so the filter can't get a good seal.
http://krif.com/oil/DSC03211.JPG
Hi Jan
email sent.
I think we're talking about the same thing. I need the hockey puck thing with the two oil lines that the oil filter screws onto.
Yep same thing, I'll digg it out tonight and shoot you a couple of pictures. Those hoses are coolant hoses on the hockey puck thingNot sure how they managed to bend it, that lip is pretty stiff ... did you take it apart and had a loock seems like just the oil filter gasket/seal is popping out maybe if you take it off and install it properly it works?
Hi Jan
I havent pulled it apart but from what I can see the puck thing is bent. When you get a look at yours please let me know.
Jim
Jim take off the filter and put a new one on .. is the filter hitting the idler arm when ya cut the wheels???
Hi Dan
The old filter was and got a hole in it. I've been useing a shorter one since the long one sprung a leak. Do you think that's what casued the damage?
