Wrong cam sensor voltages?
turbowrenchhead
Drive like you stole it!
I followed the directions. I pluged in my dvom and hooked one led to battery ground and backprobed the middle wire to the cam sensor. I would get 10.xx volts and when it hit the window 6.xx volts. Is this wrong? I thought it was suppose to be 7.5 or 0 volts. I set the sensor to where the voltage dropped hoping its right. The maf or iat wasn't plugged in. I think thats it. I temporarly hooked it all up. I dont know if that will effect the voltages or not?
