I'm getting heavy knock retard readings whenever I go to WOT whether from a dead stop or at a roll. It only does this for the first couple frames and then the knk falls off. I've tried different chips but nothing seems to help this problem. At the track, with pure race gas the problem seems to diminish somewhat so this leads me to believe it isn't false knock. But on the street with 93 in the tank and only 15-16 psi boost this is a major issue. Could a bad ESC module or knock sensor be causing this? What else could I check that might help?
