I have a controller that I'm trying to bypass 12v to "prime" the alky system prior to it going into use. I got the controller off a wrecked car, so needless to say, it doesn't have all the features that I'd ideally desire.
My question is, I've heard that if you bypass the controller to prime the pump, you don't want the 12v getting back to the alky controller.
I have a shurflow pump, and if I wire in between the pump controller(not the alky controller, the thing that keeps it at the certain psi) and the pump itself (similar to bypassing the controller) will this current go back through the pump controller and back into the alky controller?
My main concern is shorting out the progressive controller.
I'd imagine I'd only have to prime the system for a fraction of a second for the motor to start to bog down. Would this hurt if I did this? Are there any one way type isolators I can pickup at my electronics store?
