Im all set except for wiring the power supply to the unit and powering the switch that will trigger the sys to ramp up boost - times over the four stages. I am thinking I will simply put in an on/off switch to activate the sys-- would that be correct? Then I would like to trigger the ramping off the transbrake. But with the transbrake button being normally open - how would the inovative sys see power to ramp up the boost launch? If I can't trigger it off the transbrake button - how could I get the sys to trigger ramp up at the same time as the transbrake triggers? Thanks- Larry
