wiring a fan
gsbuick65
putting a electric fan on my 84, was wandering the best way to wire the relays? run the pos or neg thru it? and where can I connect the pos wire?
The factory did the positive wire relay switch so that should work just fine.
I've used the back of the alternator big red stud to feed a fan relay.
IGN power to the relay coil + and ECM or temp. switch grounds for relay coil triggers.
I use snubber diodes too for added relays on the coils.
