WinALDL data logging?
granitestategn
Gettin' there
I got my WinALDL cable built and working. I got it to run fine but I don't know how to find the file that the datalogger "should" be writing to. When I press the datalogger start button it appears to be logging. When I press stop it looks like it stops. I just can't find the file. Any help out there?
Don't have it on hand, but I think it's in the same folder as the program. Maybe c:\winaldl ? It is a numbered file that likely is a date with a txt or csv extension.
Thanks Scott!
I'll give it a look when I get home. I thought the file would be accessable from the program window but maybe not. I also found out that if you have the Scanmaster "fast update" code in your chip that the data is not compatible with WinALDL. I need to get the code in my chip switched to slow update before I can believe the data.:( Too bad, I liked the fast update rate.
