i have an 86 gn, and i i am having some trouble getting it to run right it typically happens under boost but the car will cut out, the turbo will spit back as if the throttle had been shut and then it will spring back to life again, during that moment the check engine light will flash then go away when it returns to normal i put it on the scan tool and found code 44 "lean exhaust",so i checked as follows,fuel pressure,fuel injectors,plugs,wires,mass air,tps, and i cannot figure it out. but sometimes it will fall on it's face even off a stop no boost it will sputter for a second then pick back up. plese help me i have a reputation driving around one of the only blacked out buicks around my area.
