Not too fond of the LC-1 anymore.
Im thinking of getting a wideband dont really need to log my runs [confusing].What would be a good choice .Right now im using my scanmaster 2.0 and a egt guade .What would be a good choice thanks and what AF do you shoot for with alky thanks John
Why???
Been through two sensors and keep getting error codes. Tried recalibration multiple times, and the system seems to go out when it wants. For the price, its not worth the hassle. I went to their forum and see im not the only one with these issues.
I had one on a friends car that we had problems with. After extensive troubleshooting we determined that the controller had to be damaged internally. I feel the location of the controller played a key role in the systems failure. IMO the controller suffered heat damage from being in the engine compartment. Electronics and heat don't mix. After replacing the unit and relocating inside the car, it has been trouble free.
FWIW Mine has been inside the car from day one. Has worked flawlessly for a couple years now.
Rick
Most issues with the LC-1 can be traced back to improper grounding. The LC-1 needs to be grounded on the firewall, at the same location as the engine block grounds.
How often do you recalibrate the sensor?
