Whizzing air sound under boost???
S
speedy1320
Guest
Anyone experience this before? On warm days this is MUCH more noticeable than cold days......
Under Boost, I am hearing a "RUSHING AIR" sound.....almost like an exhaust leak....BUT....the car Boosts FINE and RUNS strong!!!
Now don't get me wrong.....this isn't the Turbo "Whistle" or the sounds normally associated with Turbo Charged Incoming air.....It sounds like it is on the drivers side......but i cannot define it.
I have replaced my IC hoses, Turbo lines, changed the air filter...looked for exhaust leaks......NADA
What the heck could this be????:confused:
Tom
87WE-4
Stock Turbo,32# injectors, CAS V-4, 3"DP, 3" Cat, PP, 14" ATR filter
RE :Jim
Jim, if it is an intake leak how can I find it??? {Spraying the manifold with WD-40 might not show it at idle since it happens under Boost...}
And let me ask you THIS......DID THIS SOUND0 OCCUR WITH YOUR CAR FROM THIS LEAK?
Thanks!!!!
{By the way, I live in the Bordentown area!}
Tom
RE: PRISRIZD
EGR.....REALLY? {This is the "little guy" that taps into the air intake by the MAF right?}
I gotta tell you, I don't know if it could be this, because this sounds more like PRESSURIZED AIR VS DRAWN air.... know what I mean?
Anyway, the EGR is intact and fits warmly into an ATR rubber collar that houses the 14 K&N.......looks good to go IMO
Thanks!!!
Tom
Nope thats MAT, EGR is the round gizmo on the drivers side of your intake manifold. it has a black cover on it. If you reach underneath it you should feel a diaphram. If you have the car running and move this diaphram it should effect the idle.
RE PRISRIZD
AHHHHH gotcha! So are you saying that it's possible that the diaphram has a leak in it? What exactly does this do anyway?
Are you saying that this can be "moved" and thereby I will notice a difference at idle?
Sorry about all the questions......But I am learning FAST Thanks to you guys!
Tom
Re: RE :Jim
Thanks!!!!
Tom
Hi Tom.
My car had a blowing thru a blade of grass kinda noise. I found it one day when cleaning my engine. There was oil residue blown UP the LS valve cover. The noise went away warm I ASSume due to everything expanding
BTW: I'm in North Jersey, umm..kinda by Morristown..I'm about 1:30 from Etown.
RE: TURBOV6
The IC Hoses were the FIRST place I looked{And I just replaced them for giggles but no change} ....but it SOUNDS EXACTLY like that NASTY NOISE....Only, I am not losing boost And the car is Pulling hard!!!????
I am going to take a Good Hard look at the intake this weekend, as per Jim Testa's idea of a possible manifold leak.
Thanks for all the Good info guys!
Tom
Check the bolts on the turbo. Both on the compressor side and the exhaust side. When I got my new turbo they were loose, and did make a similiar sound. The problem went away after tightning the bolts.
I'd check the egr solenoid hose. I blew it off and heard that hissing w/o a loss in power.
