Which piston rings
turbo6man
What brand and style of piston rings are being used with good success for 22+psi boost. Any shared good or bad experiences would be greatly appreciated:D :D :D
I like Total Seal rings which are file to fit. Leakdown is minimal unlike other rings that over time will not seal as well.
-GNX7
Have you ever tried the gapless rings from total seal? When you buy file fit rings do you file the rings for the top groove only or is the second groove a file fit also??? As a rule of thumb is'nt it true you allow about four thousandth's per inch of bore? so a 4" bore would need a ring gap of about 16 thousandth's???? Any idea what that .016" gap becomes at operating temp??? Thanks for the previous reply. Turbo6man
